<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
</p>
Inch to mm
ehsan_pazooki
Member Posts: 52 ✭
Hi guys, I changed the size settings of my Onshape to millimeter. But I still see tha value of dimensions in Inch. Each time if I want to define a surface or something, I must write not onlye 5 or 23 (as an example) but "5 mm" and "23 mm". If I do not write "mm", it will be defined in Inch. Is there any way to fix this?
Setting units defaults is only for new documents. To change the units of the current doc, look in the "hamburger" menu next to the Onshape logo top left.Senior Director, Technical Services, EMEA1
You will need to set your document units to mm.
The Onshape account setting (i believe is what you changed) is the default for new documents5
The Onshape account setting (i believe is what you changed) is the default for new documents5 -
