Filter instantiators to not show plans, Mate connector.
DAS
Hi, I'm starting to handle FeatureScript, I wanted to know if there is a way to filter instantiators to not show plans, Mate connector.
import(path : "13fb9636d7d0307d8a5162a6", version : "efe9ea3071740725a074f15c");
export enum SeletModel
annotation { "Name" : "Type_0" }
Type_Z,
annotation { "Name" : "Type_A" }
Type_A,
annotation { "Name" : "Type_B" }
Type_B
annotation { "Feature Type Name" : "Instance" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
// Define the parameters of the feature type
annotation { "Name" : "REAR WHEEL", }
definition.SeletModel is SeletModel; //=========
annotation { "Name" : "Rear_1" }
isAngle(definition.Rear_1, ANGLE_360_BOUNDS); ///------>
annotation { "Name" : "Stak" }
isLength(definition.Area_1, { (millimeter) : [1e-5, 600, 1e5] } as LengthBoundSpec);
annotation { "Name" : "Reach", "Default" : 50 }
isLength(definition.Axis_Z, { (millimeter) : [1e-5, 600, 1e5] } as LengthBoundSpec);
// Define the function's action
const instantiator = newInstantiator(id + "instantiator");
if (definition.SeletModel == SeletModel.Type_A)
addInstance(instantiator, build, {
"partQuery" : qConstructionFilter(qEverything(EntityType.BODY), ConstructionObject.NO), //???
"configuration" : {
"SeletModel" : SeletModel_conf.Type_B,
// "Orientation" : SeletModel_conf.[definition.SeletModel],
"Axis_Z" : definition.Axis_Z,
"Area_1" : definition.Area_1,
"Rotate_1" : definition.Rear_1
"transform" : identityTransform()
if (definition.SeletModel == SeletModel.Type_B)
"partQuery" : qConstructionFilter(qEverything(EntityType.BODY), ConstructionObject.NO), // ?????
"configuration" : {
"SeletModel" : SeletModel_conf.Type_A,
instantiate(context, instantiator);
1
How to filter the "Plane" and lMate connector
https://cad.onshape.com/documents/1c29fe218a63aa8e0fcdc382/w/2591152355d300f944f280c5/e/da4bdb1277ab6124ca3a093c
Thanks MBartlett21
This solves my doubt my problem"partQuery" : qBodyType(qEverything(EntityType.BODY), BodyType.SOLID),</code>"partQuery" : qConstructionFilter(qEverything(EntityType.BODY), ConstructionObject.NO), // ?????</pre><br><blockquote class="Quote"> <div><a rel="nofollow">MBartlett21</a> said:</div> <div>@DAS<br>Can you use <code>qBodyType(..., BodyType.SOLID)
I leave this little example here ...import(path : "13fb9636d7d0307d8a5162a6", version : "a209c9a751a978707c2f3ea8"); export enum SelecMod { annotation { "Name" : "NOT" } NOTTT, annotation { "Name" : "Type_A" } Type_A, annotation { "Name" : "Type_B" } Type_B, annotation { "Name" : "Type_C" } Type_C } export const SelecType = { SelecMod.Type_A : SelecModel_conf.Type_A, SelecMod.Type_B : SelecModel_conf.Type_B, SelecMod.Type_C : SelecModel_conf.Type_C }; export enum SelecFilter { annotation { "Name" : "Type_A" } Type_A, annotation { "Name" : "Type_B" } Type_B, annotation { "Name" : "Type_C" } Type_C } export const SelecTypeFilter = { SelecFilter.Type_A : qConstructionFilter(qEverything(EntityType.BODY), ConstructionObject.YES), SelecFilter.Type_B : qConstructionFilter(qEverything(EntityType.BODY), ConstructionObject.NO), SelecFilter.Type_C : qBodyType(qEverything(EntityType.BODY), BodyType.SOLID) // SelecTypeFilter[definition.SelecFilter] }; annotation { "Feature Type Name" : "Instance" } export const myFeature = defineFeature(function(context is Context, id is Id, definition is map) precondition { // Define the parameters of the feature type annotation { "Name" : "REAR WHEEL", } //========= definition.SelecModel is SelecMod; annotation { "Name" : "REAR WHEEL", } //========= definition.SelecFilter is SelecFilter; annotation { "Name" : "Rear_1" } isAngle(definition.Rear_1, ANGLE_360_BOUNDS); ///------> annotation { "Name" : "Stak" } isLength(definition.Area_1, { (millimeter) : [1e-5, 600, 1e5] } as LengthBoundSpec); annotation { "Name" : "Reach", "Default" : 50 } isLength(definition.Axis_Z, { (millimeter) : [1e-5, 600, 1e5] } as LengthBoundSpec); } { // Define the function's action const instantiator = newInstantiator(id + "instantiator"); if (definition.SelecModel != SelecMod.NOTTT) { addInstance(instantiator, build, { // include sketches, only exclude default "partQuery" : SelecTypeFilter[definition.SelecFilter], "configuration" : { "SelecModel" : SelecType[definition.SelecModel], //SelecModel_conf.Type_A, "Axis_Z" : definition.Axis_Z, "Area_1" : definition.Area_1, "Rotate_1" : definition.Rear_1, }, "transform" : identityTransform() }); } instantiate(context, instantiator); });<br>
