I am having trouble building a Rack for a school project.
malachi_caprietta
Member Posts: 2 ✭
I'm pretty new to OnShape and I'm struggling. I need this final piece to be able to assemble my project. I will take any help I can get as I don't even know where to start.
Thanks.
Thanks.
mahir
Member, Developers Posts: 1,320 ✭✭✭✭✭
I'm guessing you're struggling with all the teeth since the other parts are relatively straightforward extrude and hole features.- First, model the rack without the teeth - either with less material (stop short of the teeth) or more material (extrude past the teeth).
- Next, model one tooth with the dimensions provided in Detail A.
- Extrude that tooth - either adding or removing material depending on what you did in the first step.
- Use a linear pattern to add the rest of the teeth. There are several of options here depending on how you want to go. Feature pattern is the easy/lazy way, but part and face patterns are preferred since they are less computationally expensive.
Introduction to CAD
Onshape Fundamentals: CAD6
I suggest you look into the beginner tutorials. They cover all the basic modeling techniques you would need to design something like this.Introduction to CAD
