Dimensions Over Constrain Sketch By Default?
larry_hawes
Member Posts: 478 PRO
in Drawings
Not sure how to ask this and I think I see what is happening but it's bugging me to no end. Sketch a rectangle, extrude. Sketch another rectangle that aligns with outer edges of previous rectangles and is constrained coincidentally at expected lines and points. Enter dimensions, cause I don't know what else to do complete the sketch, and the sketch is over constrained because it really doesn't need at least one dimension as it is already constrained coincidentally along that dimension.
Can the second rectangle be created without dimensions? Or some simple method to keep this kind of sketch from being over constrained?
http://www.youtube.com/watch?v=6stKRJmbtP4
http://www.youtube.com/watch?v=6stKRJmbtP40
steve_shubin
Member Posts: 1,118 ✭✭✭✭
@larry_hawes
I thought maybe this is an interface thing.
Maybe it’s different on the desktop then it is on the iPhone.
I went and got my MacBook and opened Onshape
Below is the screen capture
I entered the horizontal dimension, and there was no need to enter the vertical dimension as it was constrained to that of the cuboid. Then I deselected the tool. And there was nothing overconstrained
5
After sketching the rectangle on the face of the cuboid, deselect the Centerpoint Rectangle Tool in the tool bar before entering any dimensions
In the above GIF, I answered your first question which is can the second rectangle be created without dimensions
Think of a constraint as like an anchor. So if I snap (constrain) the bottom horizontal line of the second rectangle to that of the cuboid, and if I constrain the top horizontal line of the second rectangle to the top line of the cuboid, and then if I try to add a dimension between those two lines, the program is going to say no no no. The bottom horizontal line of the second rectangle and the top horizontal line are locked in place you cannot move them. If you want to move one of those lines of the second rectangle, you’re gonna have to release one of those constraints
If you want to add a dimension from the bottom horizontal line to the top horizontal line of the second rectangle, then when you are sketching that second rectangle, don’t allow it to snap to one of those horizontal lines on the cuboid
You can add a dimension to the width of the second rectangle and it will not go into overconstraint, as long as you don’t snap both vertical lines of the second rectangle to the vertical parts of the cuboid when sketching the second rectangle
My pleasure. That’s good news to hear that it worked out Larry
