Step problems
Hi
I have a problem with Onshape ( I am new to it)
I get the following when i import a step file. Can anybody help me with this?
    You should have another tab at the bottom (click the house icon to go up a folder) that includes the 3D model.
  • john_mcclary
    When you import a file that can be translated into a 3D model, keep your eye on the notifications menu.
    If it says Importing... Then Onshape is in the process of translating it into 3D model.
    Once it is finished, you will see some part studios and assemblies appear (depending on your import type)
    Importing can take a few minutes depending on the  size of your model. Your's is 70mb so I would give it a couple minutes.
    If there was a problem this notification well tell you if there was any import errors also.
