Fun times with the Loft feature...
I've been lofting in 3D software for two decades and it's always a treat. Sadly, Onshape is no different.
Here's a good one: lofting from a rectangular sketch to a cross-shaped one. Possible? I tried to cheat by carefully placing 8 points on my "rectangle" in a very specific order, and then constraining pairs of points to each of the 4 "corners" of my rectangle, and carefully creating my cross sketch using 8 points as well (well 8 points + 4 center points as I was using the arc tool).
The results are exactly the same as if I had used 4 points on the rectangle, so I'm guessing that Onshape is too clever for me (it doesn't take much). I tried matching vertices but that had no (positive) effect. If anyone can figure out how to loft these two shapes please post your doc!
mahir Member, Developers Posts: 1,316 ✭✭✭✭✭
Is this closer to what you're trying to do? I'm not sure what your intent is.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/ba9399339fd065915be3680e
6 -
You needed more points and/or line segments. You had 8, but what I did requires 12. This was so I could map the corners to the arc midpoints. I didn't have to match vertices. I think Onshape already picks the path of least resistance (shortest point-to-point mapping), so vertex matching wasn't necessary. Similarly, the order in which you create the points doesn't seem to matter. Feel free to click the link above and make a copy of the part studio. That way you can poke around.5
