String Parameter won't reference a Text Config Variable
sam_parsons
Member Posts: 43 PRO
Hey Guys,
I'm trying to use a custom feature to assign materials to parts. But I'm getting tripped up by the string parameter. I can't seem to configure the parameter using a text config variable? Presumably because "#" becomes part of a string and loses it's ability to signify another variable?
Here is the annotation in FS:
Sam
annotation { "Name" : "Core Material", "Default" : "Default" }
definition.coreMat is string;Any thoughts would be greatly appreciated!Sam
Instead of defining the annotation as a string, define it as a field that accepts anything (including variables). As you said, forcing the input to be a string will just use whatever text you enter as is, including the #.
So instead ofdefinition.coreMat is string
useisAnything(definition.coreMat)
Keep in mind that this will allow just about anything to be entered - variables, functions, numbers, booleans, and of course text strings. To insure whatever is entered is treated as a string later in the FS, you may need to typecast via toString().2 -
Alternatively, you can use a little coding to remap the #variable to its value.
See an example function I have for doing that below:/** * This function maps variables denoted by `#variable` to the appropriate variable in the context. */ export function remapVariables(context is Context, text is string) returns string { // An optimisation if there is no variable references if (replace(text, "#", "") == text) return text; var variables is map = getAllVariables(context); variables[" "] = ""; // Replace "# " with "" var out is string = ""; const chars is array = splitIntoCharacters(text); const charsSize is number = @size(chars); for (var i = 0; i < charsSize; i += 1) { const char is string = chars[i]; if (char == "#") { if (i < charsSize - 1 && chars[i + 1] == "#") { out ~= "#"; i += 1; continue; } const varName = getVarName(chars, i + 1); if (varName != undefined && variables[varName] != undefined) { out ~= toString(variables[varName]); i += length(varName); } else out ~= char; } else out ~= char; } return out; } function getVarName(chars is array, i is number) { var out = ""; for ( ; i < @size(chars) && nonSpecial[chars[i]] == true; i += 1) out ~= chars[i]; if (out == "" && i < @size(chars) && chars[i] == " ") return " "; return out == "" ? undefined : out; } // This uses a function to generate a constant. const nonSpecial is map = function() { const chars = splitIntoCharacters("1234567890_qwertyuiopasdfghjklzxcvbnmQWERTYUIOPASDFGHJKLZXCVBNM"); // All alphabetic characters var out = {}; for (var char in chars) out[char] = true; return out; }();
Perfect! I'll try this for now.mahir said:Instead of defining the annotation as a string, define it as a field that accepts anything (including variables).
But I can see how this would be useful long term, just not sure I know enough about feature script yet to implement it. Do you just include this in the custom feature code?MBartlett21 said:Alternatively, you can use a little coding to remap the #variable to its value.0 -
@sam_parsons
If you put the code above in your FeatureStudio, you can then use it in your code just after the end of the precondition:definition.codeMat is string; // The rest of the precondition } // End of precondition { // Start of feature body definition.coreMat = remapVariables(context, definition.coreMat); // Continue the rest of the code
ok thanks, I may try this at some point. For now, I've got @mahir 's method working... however... I get the same problem when I insert that part into an assembly, I get the same issue in the change configuration in UI. Any ideas?MBartlett21 said:
@MBartlett21 , would your method solve this ^ ?0
