Using Transform Assembly Occurrences API Call
Hello,
I want to be able to move parts around in an assembly with an API Post, and believe the "Transform Assembly Occurrences" call will do that, but can't figure out the JSON syntax. I'm taking the occurrence string from the "Assembly Definition" Get request. Here is one of the request bodies I've tried:
"occurrences": "{ "path" : [ "M+71F+lRPMmz6IrdH" ], "transform" : [ 0.0, 1.0, 0.0, -0.01222426182365419, -1.0, 0.0, 0.0, 7.397456422448163E-4, 0.0, 0.0, 1.0, 0.026334691189542413, 0.0, 0.0, 0.0, 1.0 ], "fixed" : false, "hidden" : false }",
"occurrences.0": "{ "path" : [ "M+71F+lRPMmz6IrdH" ], "transform" : [ 0.0, 1.0, 0.0, -0.01222426182365419, -1.0, 0.0, 0.0, 7.397456422448163E-4, 0.0, 0.0, 1.0, 0.026334691189542413, 0.0, 0.0, 0.0, 1.0 ], "fixed" : false, "hidden" : false }",
"occurrences.0.path": "M+71F+lRPMmz6IrdH",
"transform": "[ 0.0, 1.0, 0.0, -0.01222426182365419, -1.0, 0.0, 0.0, 1.0, 0.0, 0.0, 1.0, 0.026334691189542413, 0.0, 0.0, 0.0, 1.0 ]",
"isRelative": "False"
Thanks,
Matt
Thanks,
Matt
