Is there a method by which an angular limit to the 3 rotations in a Ball Mate can be achieved?
StephenG
StephenG Posts: 384 ✭✭✭
edited June 2020 in Community Support
The Ball Mate doesn't allow a range of min/max angles for the 3 degrees of rotational freedom.
Trying to restrict angular movement to reflect a hard interference limit in an mechanism.
  • StephenG
    Thanks for the advice. I tried it and it worked.
    However I only needed 1 parallel mate to achieve the desired effect.
    Note: I used a surface as a the dummy part.
    (Comment: Shame the Ball mate doesn't have a rudimentary way to limit the amount of rotation about the rotational 3 DOF.)
  • mahir
    mahir Posts: 1,324 ✭✭✭✭✭
    Glad it worked out for you. Yeah, one parallel mate makes sense. For some reason I thought the Z rotation DOF needed to be removed, but it doesn't.
