Parametric model export with Python
thales_maiathales_maia Member Posts: 10 EDU
I  saw some posts related  to Python and OnShape, but couldn't find any doc about it. I appreciate if someone can point me a direction.
I use a finite element program for magnetic field. This program accept dxf as input. I was using FreeCAD with variables. Using Python, I update the variables, export dxf and import that automatic to my fem program.
I want to use it with OnShape. I know that is possible to model with variables. Is it possible to update those variables using Python and download a dxf?
  • thales_maiathales_maia Member Posts: 10 EDU
    No one?
  • pmdpmd Member, Developers Posts: 64 PRO
    You can in theory do this from Python using configurations and the Onshape API - I am not sure if there is a way to directly just set variables.
    One issue may be getting the drawing to change configuration - in Onshape (and their API) part studios and assemblies have configurations but drawings do not (a drawing can contain parts/assys with configurations).
    I do not see any documented way to get a DXF version of a sketch from a partstudio as a DXF but you can get a DXF of a Drawing.
    Full info on the API and various language support is at https://dev-portal.onshape.com/
    Note the API info link is the word "here" on the above page which can be easy to miss...
    Thanks. I see that is not a trivial task.
