Is there any way to prevent laser joint sockets from penetrating both walls of a tube?
DGF65
DGF65 Member Posts: 3 PRO
I have successfully created pins and sockets on tube joints, however i cant find a way to prevent the sockets from extending right through the far wall of the second tube.
See example https://cad.onshape.com/documents/7b1fcf924bc3bd3b89b96777/w/702e3f28adb5dedf3c2d04c3/e/bc9a81099715333be1df8ed5
am i overlooking something?
  • DGF65
    Thanks Arul, i will keep an eye out for an update.
    I see it being really helpful for design of tube laser cut projects.It is already brilliant for sheet cut asse
    thanks also Evan and fnxf for your workarounds.
