Getting parameters of a selected curve?
S1mon
Member Posts: 4,644 PRO
Am I missing something obvious? Is it possible to select an edge or curve and treat it as a BSplineCurve? I see the "CanBeBSplineCurve" typecheck, but I'm not sure how to get the control points from an entity if that's true. If I just created a curve with a custom feature, will I be able to extract the same control points that I used to create it in the first place?
I'm trying to do this because I want to create an approximate offset which is the same degree as the base bezier curve, using something similar to Tiller and Hanson's offsets.
https://math.stackexchange.com/questions/465782/control-points-of-offset-bezier-curve/467038
1
