If you would like to contact our Community Manager personally, feel free to  send a private message or an email.
Origin Defined Differently in Onshape and Simscale.
 Robert01
                    Member Posts: 22 ✭
Robert01
                    Member Posts: 22 ✭
                    I noticed the origin is defined a bit differently between Onshape and Simscale. In Onshape, the origin is defined at the intersection of the (Left, Front, Bottom) planes and in Simscale the origin is defined at the intersection of the (Right, Front, Bottom) planes. This could potentially make things a bit confusing when importing a geometry from Onshape to Simscale. Is there any way to change the default axis/origin point or names of the planes in Onshape to match Simscale since I do a lot of exporting of parts to Simscale for simulations? Thanks.
I know it's not so clear cut as to what are SimScale and Onshape developments in this regard, and technically it could be either, I suppose. However, in future might be worth mirroring the discussion here.
All the best,
Darren
