Will not let me extrude parts of a shape.
tyler_willsontyler_willson Member Posts: 4 EDU
I had my part designed, but after I created a pattern of it, it seemed to create a few small holes. If I go back to the original extrude, it will not let me add the little corners and holes to
be extruded.
It just wont let me add them to the parts of the sketch that are being extruded. I'm not even sure where the slivers came from to begin with.
Any help would be appreciated!
  • alnisalnis Member, Developers Posts: 453 EDU
    If you trim the geometry on the inside so that it's just a single face region, does it work?
  • fnxffnxf Member, User Group Leader Posts: 146 PRO
    You're extruding faces of a sketch..  after a extrude has been done, Onshape will hide the sketch. Maybe that's why you're not able to select the faces.
    Try making the sketch visible first, then editing the Extrude 2 again.
