Hello, how are you? how do you go about an already imports file?
for example like extrude, creating holes, revolve, and other no usual shapes
  • bruce_williams
    @ssenyonga_mervyn
    Welcome to the forum and Onshape!  We use imported geometry all the time.  If your model imports without error and a solid is created, you will have no problem using the standard tools to add or change.  See the on-line tutorials for more help.
    www.accuratepattern.com
  • scott_holderness
    scott_holderness Member Posts: 1 ✭
    I imported an .stl file but am unable to change the file, ie edit sketch see screen shot thanks for the help
  • mark_leichliter
    mark_leichliter Member Posts: 12 ✭✭
    .STL is a mesh format, and as such can't be edited like native Onshape geometry.
  • GWS50
    GWS50 Member Posts: 529 PRO
    Boolean Plus, by MBARTLETT, is a custom featurescript and is excellent when working with STL's which are notoriously tricky when trying to use in the CAD environment
