"change to version" in drawing gone...
Dear all,
I am experimenting with the PLM / PDM side of Onshape and run into to following situation:
- I modelled a part
- I made a drawing containing this part
- I released the part (not the drawing)
- Then I tried to release the drawing and then Onshape tried to release the part again, so to B. This is unwanted.
- Found a solution by "relate to version" so the drawing is specifically looking at the released version of the part.
- Now I can release the drawing without creating a new revision
- Next step is to further work on the part. Implementing changes.
- Now I want to let the drawing look at the latest part version again....but I cannot find the "change to version" option anymore...It is not in the RMB options anymore...I tried creating a new version, but no succes.
Can anyone tell me how I can make the drawing look at the latest part version again?
Best regards,
Dennis Varkevisser
- I modelled a part
Best regards,
Dennis Varkevisser
tim_hess427 Member Posts: 648 ✭✭✭✭
Once a drawing is referencing a version, I think you need to click "Update Linked Document" in the RMB menu.
Once you click this, you can go back to referencing the "workspace" or a specific version.5
