[FIX] Firefox Shift + 7 = / (Quick find shortcut) in Spanish keyboard
emagdalenaC2i
Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
In a QWERTY Spanish keyboard SHIFT + 7 = / as you can see
And the shortcut "/" is associated with the "Quick find" option in Firefox
So whenever I tried to switch to an isometric view in Onshape, I open the quick search bar in Firefox
But, here is an easy fix to avoid this issue.
- Open Mozilla Firefox and type about:config in the addressbar and press Enter. It'll show you a warning message, click on "I accept the risk!" button.
- Now type typeaheadfind in Search filter box and it'll show following preference in the window: accessibility.typeaheadfind.manual
- This preference is set to true by default. To disable the feature, double-click on accessibility.typeaheadfind.manual preference and change its value to false. Alternatively, you can right-click on the preference and select Toggle option.
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común
1
