Change drawing view reference
I know this has been commented on in other requests such as https://forum.onshape.com/discussion/comment/54734#Comment_54734
However, unless I'm missing something there is no way to change the view reference. The situation I come across often is when a part is split. This results in two or more entities for a view to reference. If you had a drawing going of the un-split part then after splitting the part the drawing will reference is usually not the part of the split you want in the drawing. I'm sure there is logic to what the view chooses but that isn't apparent. Normally, it is common to change the view reference in the view properties but that feature isn't there. You can open the linked part but can't change it.
All the ideas relating to this have been closed so I'm hoping Onshape has added this feature and I'm simply not finding it.
Thanks!
Thanks!
This is already in Onshape: https://forum.onshape.com/discussion/12261/improvements-to-onshape-september-11th-2019/p1
IR for AS/NZS 1100
