How can I check in FeatureScript to see if a variable (defined in a configuration) exists?
I want the FeatureScript code to check to see if the configuration variable has been created and then use (if then else) in the following code to respond appropriately. I don't need the configuration variable to be defined by the user and thus if it isn't defined I'll simply create it within FeatureScript.
