Converting a solid to sheet metal, preserving outside dimensions
Isaac_BaerIsaac_Baer Member Posts: 4 PRO
I can't figure out how to convert a solid to sheet metal in a way that preserves the outside dimensions. In other words, I can only make a sheet metal model that contains the solid, not one that fits inside a solid. Is this possible? Most of the time, this is more useful to me than the default option.
  • romeograhamromeograham Member, csevp Posts: 733 PRO
    Try selecting the "Opposite Direction" button next to the Thickness dialog:
    Should work for you.
    Good luck!
  • lanalana Onshape Employees Posts: 752 image
    While on this topic please notice that you can specify additional clearance
    And have it enforced for bends as well:
  • matthew_stacymatthew_stacy Member Posts: 489 PRO
    @lana , thanks for the clearance from input and include bends tips!  Learned my new trick for the day.
