Having trouble trying to loft
anthony_glorioso
Member Posts: 2 EDU
I'm trying to loft these two faces together but I can't seem to get it and keep running into
https://cad.onshape.com/documents/e32265338f801ae395ff3dcb/w/4a47d3b1a46422e778228c72/e/91bcbb6062fe8adf7101835c
You will need to give this one some help. Loft likes to match vertices so either do like I did below (a single side surface at a time) or split your rectangle into the same number of vertices as the thread and manually match them up. Going to take some trial and error to get what you want. You may also want to extrude the rectangle to control curvature.
Thanks, That is good enough for me!
Here is the end result. Let us know how you make out!
https://cad.onshape.com/documents/b7e8dc64952bbee6a454ab78/w/f0f5da25a2d65755f62db861/e/08eeb917483d7b6aa515ef19
