circle to center area
milan_vaznymilan_vazny Member Posts: 2
hi all
can anyone help me? i am need put small circle (dia 6.5) exactly to center selected area (yellow).
    edited September 2020
    @milan_vazny
    You will need to work with constraints and another construction line
    If you explain or better yet show what you are after we can give you more specifics.
    www.accuratepattern.com
  • BenTaylorBenTaylor Member Posts: 48 PRO
    One way to pick the center of a region is to use a mate connector. If you finish the current sketch and then create a new one, you can choose to create the sketch on a mate connector. If you then hover over that area, you should be able to select the center of that area. I'm not sure exactly what OnShape uses to calculate the center (centroid? midpoint of arcs?).
    Ben Taylor
    Lead Mechanical Engineer @ Healing Innovations
