A create line feature should be added with title "point direction"
akhtar_basitakhtar_basit Member Posts: 2
edited October 2020 in Using Onshape
Good that we can create 2D, 3D curves outside of sketch. And great that we can create a "line" using bridging curve using position option. HOWEVER, a simple line command is sourly needed where you can just pick a point (for the line to pass through) and then a plane (for the line to be normal to). This new line should be added to the "create a plane" menu. That is, the create a plane menu should be renamed to something like "Construciton entities". one could use this line to act as a pulling direction, extrude direction, as an axis for revolve, plane creation etc.
  • romeograhamromeograham Member, csevp Posts: 741 PRO
    You can use Mate Connectors this way. You can create them anywhere you like, reorient them, rotate them etc. The Z axis is normal to the XY plane (of course) and would act like your line above.
