For loop, sum up to the current loop?
MichaelPascoe
MichaelPascoe Member Posts: 2,960 PRO
edited September 2020 in FeatureScript
Is there a way to sum up to the current loop? The loop calculates an angle, I need the n'th loop to add up all of the previous loops angles.
for (var i = 1; i < nSegments; i += 1)
            var = sumOfPreviousSegmentAngles =
            var segmentAngle = atan(d / sqrt(i))/degree;
  • MichaelPascoe
    Thank you, I will try this.
  • konstantin_shiriazdanov
    And didn't noticed it from the beginig, but since you dividing the result of arctan by degree you don't need degree units for sumOfPrevousSegmentAngles, so just
    var sumOfPrevousSegmentAngles = 0;
  • Jake_Rosenfeld
    ^ Also though it is usually better to keep the units attached to unit-ed values.  This ensures proper use of those values down the line and helps prevent mistakes.
