Add ability to add Continuous Feature (CF) symbol in drawings introduced in the 2009 Y14.5 standard
Eric_WongEric_Wong Member Posts: 24 PRO
The <CF> symbol is incredibly useful when designing shafts, and allows for drawings to convey information that could not be previously communicated without a hefty note block. See the attached image for an example of its use. This symbol should be added to bring Onshape closer to meeting the 2009 ASME Y14.5 standard
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 577 image
    @Eric_Wong I've created a support ticket for you on this and will attach you directly to the improvement. We are working in this area to bring more support to full GDT needs.
