Won't accept the correct answer to my Data Management Learning Curve last question LINKED DOCUMENTS
ENNELLDEE
ENNELLDEE Member Posts: 3 ✭
I only need to answer the last question, which I did, in the Data Management Learning Curve sections which is the Linked Documents question. I answered it correctly at which point it should have sent me to get my certificate, but it won't accept the correct answer. So I can't get my certificate.
How do I get my certificate?
  • ENNELLDEE
    I answer the question and it says "That's Correct!" When I hit the "Continue to Next Section" It should take me to get my certificate but it start me over with the same question.
  • ben_lichtenstein
    ben_lichtenstein Member Posts: 1 EDU
    Identical problem, and per this screenshot it is not the 89% issue mentioned above. Any other ideas how to complete the course and receive the certificate?
    thanks, ~B
  • KatieHuffman
    KatieHuffman Member, Onshape Employees, Developers Posts: 194 image
    @ben_lichtenstein I believe if you watch the videos that don't have checkmarks next to them you will be able to complete the course.
