Cannot make a rack and pinion
daniel_ramirez154
Member Posts: 2 EDU
https://cad.onshape.com/documents/3c16bf67fdbb0dcdfa5ccc50/w/055c0b5a7bf71dd581774b01/e/ff548af1f3aa1c27b3f89bf0
On the left gear and middle vertical gear on the assembly whenever i use the slider and revolute mate it gives me an error. Any way i can do this?
@daniel_ramirez154 , I was not able to figure out the specific cause of your problem. But when struggling with a model it can be helpful to isolate the specific components involved and focus on the individual tool. The full assembly offers too many opportunities for conflicting mates and other complications.I stripped your model down to the bare essentials to explore the rack & pinion relation. Focus on the three key components:
- Base (a convenient frame of reference to mate the other components to)
- Pinion
- Rack
Insert those three components into a new assembly:- FIX the Base Plate (to lock it in place)
- Apply REVOLUTE mate from Base Plate to Pinion
- Apply SLIDER mate from Base Plate to Rack (using the custom mate connectors created in the part studios)
- Apply RACK & PINION relation between the REVOLUTE and SLIDER
Here is a link to the simplified model: https://cad.onshape.com/documents/f0f2f7e73cad905425f30d23/w/fb1a805815d39c4d614cbcae/e/6a6af9d42fa03e0e611cb31aI hope that helps.
