Force decimals in drawing dimensions to show which tolerance it has?
Hello,
Is there a way to force the display of decimals in a dimension in a drawing:
ex: value is 30mm. with +/- 0.005
Default tolerance for dimensions with 3 decimals is set to +/- 0.005mm
How can I display 30.000   without having to force the value to 30.000- then it is underlined (overidden value)
Displaying 30.000 means it is +/- 0.005
Thanks.
Paul
  • It should do this automatically based on your sheet precision. Check in the drawing properties panel on the right that the precision is set to three decimal places (it's the third option from the top in the left tab):
    Once you have adjusted this, you can right-click the tab, export as DWT, and import it into a new document to use as a template (you can add more DWT files to that document to add more templates). Be sure to make a version in that document to reference them.
    However, the default templates have a precision of 0.123 for the ANSI Inch templates and 0.12 for ANSI metric & ISO templates, which I think is pretty reasonable. To navigate to the default onshape templates, select the onshape tab in the top left when making a drawing.
    Hope this helps!
  • Hello Alnis,
    Thank you for your answer. The drawing properties page allows to force leading and trailing zeroes, but this applies to *all* dimensions in the drawing.
    However, I did find the answer to my question in that page:
    set the "length trailing zeroes" - so that all dimensions have 3 trailing zeroes (using a precision of 0.123)
    Then I can edit individual dimensions and set the precision to 1 or 2 decimals- and it works fine (see the dimensions with 1 and 2 decimals):
    So all is good.
    Thanks.
    Paul.
  • I'm glad that you got a solution! I think I misinterpreted your question, sorry!
