Assembly animation and Interference Check
will_romberg
Member Posts: 3 ✭
https://cad.onshape.com/documents/9e51f11ba800cd4149d57b71/w/20b930d11f06c2c02e52d7d9/e/acd2c7fa440a67cfb9c05d46
Sorry, very new to the software and If I even posted the correct link. I have an assembly created with some transmission/Knuckle assemblies that are pinned together using Pin mates. I have the upper driver sticking out of the top of the assembly that needs to rotate clockwise along its axis but also needs to travel around a circular off center path in the counter clockwise direction. I need to ensure I have enough clearance and the correct total degrees of articulation in the transmission components so I do not bind up or collide with the ID of the outer housing components. The eccentric path it needs to travel is a circle around the central axis with a diameter of 0.220". How would I go about animating this and checking for collision/binding. I am sure several of my current mates are probably incorrect as well.
