Company Standard BOM Table
William_SchlundWilliam_Schlund Member, Channel partner Posts: 9 ✭✭
What is the best way to use a company standard BOM in any assembly you create?
  • mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 198 image
    At this point in time, I would recommend working from a standard document template with pre-formatted BOM columns, and then create new documents from that template document , or duplicate the assembly tab in a document if you are already there in a document.
    Regards,
    Mike LaFleche   @mlaflecheCAD
