Mate offset wrong JSON
simon_huber502
Member Posts: 2 EDU
As soon as one adds offset to a mate connection the json api returns wrong values.
So I have these two simple cases one with offset and one without. (https://cad.onshape.com/documents/de3c0aeb48b0e05db9f190a8/w/dbc292aa4648b95f56c01ab5)
The problem now is when you access them via json then the mate origin gets wrongly calculated:
On the left the one with no offset and then on the right with an offset of -2mm. Which should actually be 0.01 + 0.02 = 0.03 and not 0.01 + 2.0. So there seems to be an error.
json sources: https://cad.onshape.com/api/assemblies/d/de3c0aeb48b0e05db9f190a8/w/dbc292aa4648b95f56c01ab5/e/d1f660d0828845eb02bc5d46?includeMateFeatures=true&includeNonSolids=false&includeMateConnectors=true
https://cad.onshape.com/api/assemblies/d/de3c0aeb48b0e05db9f190a8/w/dbc292aa4648b95f56c01ab5/e/afb53e2d3183c6e8e6da1ad7?includeMateFeatures=true&includeNonSolids=false&includeMateConnectors=true
