Sheet Metal Problem ....
in General
Hallo everyone ....
I have a problem with this kind of object ...
https://cad.onshape.com/documents/fe7079a834b932efc5aba00b/w/0ce440286bfe3e505f465f9a/e/65f28f9b286524edede59524
It is impossible for me to have a correct flat view !
Thoughts? Suggestions?
For this example, I would suggest using a surface molding workflow. Construct the model using surfaces first, and finish by converting the surfaces to a sheet metal part.
Onshape Document https://cad.onshape.com/documents/3f46f5f9fa773df65300d0f1/w/f4da77f138b8f4dcad76537e/e/c3849203ff55e59762714b7c
Base sketch
Sketch for perpendicular feature
Offset each sketch with a value of zero to create the surfaces
Boolean union the surfaces together (Knit)
Convert to a sheet metal part. Let us know how you make out!
