I have 3 questions related to the same topic: Sweep Nomal
1) Is it possible to use "Sweep Normal 1" with multiple paths (derived from wrapped sketches)?
as you can see I can select only one path at a time and then retrieve the resultant and do the other.
someone can also tell me why it does not make the radius if between the first and second segment there is a radius?
2) is it possible to "adjust" the resultant of a wrap to make it refer to an axis? like putting constraints, making it composite curves, or something?
3) is it possible on Onshape to sweep with a solid? Practically simulating tool milling?
https://cad.onshape.com/documents/cd33170d1bf492f53dcf10c2/w/e0fa1b5f9cc6ef0ee3f174fb/e/72df5e6f783f7d3709a3c8b0
Thanks for your patience
