Invalid Drawing-Section-View for Composite Part or Assembly with Interference
matthew_stacy
matthew_stacy Member Posts: 489 PRO
I have encountered unusual and inconsistent behavior generating drawing section views of assemblies and/or composite parts with mechanical interference.  Here is a recent example:  https://cad.onshape.com/documents/31da0c76cf180b3cc5952b14/w/a2b2eaf6c6fd13f1be895e02/e/49a1b373eae4b958203b965f
This is a USB camera imported from the manufacturer (STEP file attached).  Mechanical interference occurs at two locations within the assembly.  That interference seems to prevent Onshape from generating a valid drawing section-view.  Thus far the only work-around that I have found is to suppress components (unacceptable) or boolean union parts together.
Here is a simplified example of two interfering parts:  https://cad.onshape.com/documents/bd653f66b2ce0a280f114e9c/w/bb5bada30a896accbcb8ecc9/e/48f6cc319f8a4dff7536b2fb.  This is a similar scenario, but it behaves slightly different than the USB camera example.
  1. Drawing of composite part generates INVALID section view
  2. Drawing of assembly, comprised solely of that same composite part, generate VALID section view
  3. Drawing of assembly, comprised of the individual piece-parts, generates VALID section view
Can anyone articulate the rules at play here?  There are numerous possible scenarios and permutations of imported parts, composite parts, and assemblies involving mechanical interference or size-on-size fits.  Thus far I am not able to consistently and reliably generate section views.  Is there a better approach than suck and see?
