Sheet Metal Cylindrical Question
I'm struggling with creation of sheet metal parts from cylindrical shapes. I create a solid, split the faces where I'd like seams, then convert to sheet metal. This offers a visual sheet metal part but no flat pattern and a red sheet metal feature in the tree. I can generally see where I'm uspetting Onshape and by changing tangents to rips in the bend table I get a buch of red modfied joint features to go along with the original red sheet metal feature, but flat patterns are generated. Rolled up in a folder called SPAM1 is another attempt at creating this sheet metal part. As you can see in SPAM1 I have similar problems and solutions to generate flat patterns. I abandoned SPAM1 because I didn't like the way my weld joint were turning out. And, I still have all the red features in my tree. Red in my design tree bothers me. It seems I'm fighting the software. Is there a better approach to this simple part.
In another twist, I need the SM in blue to be a different thickness that the SM in gray. I think if I can understand a better way to deal with my first paragragh, I can work around this.
https://cad.onshape.com/documents/687ede6be65a32c4cd5d97d0/w/495a8c7a2f8d866a76dcddf8/e/88cfc8cc70a4be9e1b2dc07e
[EDIT to add link to new document]
Here's a method to do this part - there are 5 parts, so this method requires 5 Sheet metal features.
https://cad.onshape.com/documents/4bc6fb3d3bc72c372b654c48/w/1a55fb171363add36752f14d/e/957f86a7efb6f82bb430686a
Hope this helps.
Weld! What ??? I've never seen that before and I'm sure exited to figure that out.
Thanks again for helping and sharing.
