Creating plane problem
gregan_pace
Member Posts: 5 ✭
I'm trying to create a plane to basically cut a corner off of a square and I'm having a problem doing it. I'm not an expert in any cad software, so maybe I'm just going about it the wrong way. I just created sketched lines on all three sides of the corner and then have hit the plane button and selected the 3 lines, but they none of the plane options seem to do anything once I have created the plane. If there is an easier way to just cut the selected corner from the square, I would just do that as well.
cody_armstrong
Moderator, Onshape Employees, Developers, csevp Posts: 221
@gregan_pace Select the endpoints of the lines. Not the lines themselves.6
at present this is not explicitly an option.
The workaround is to select the endpoints of the line, and the remote point, and make a plane through three points.
