Can I make one piece two different colors?
nate_brown788
Member Posts: 4 PRO
I'm doing a project for my CAD class and I'm making a lot of the same exact part but each one needs to be a different color. I've been making the part individual each time just so I can have it be another color. Is there anyway way to make one piece have multiple colors in an assembly?
romeograham
Member, csevp Posts: 756 PRO
For your application, you can configure the color of the part in the Part Studio. You need to create a Configuration table, then in "Configured Part Properties" you set color for each body.
Then, in the Assembly, you can change the configuration of each instance as needed to get the colors you want.
You can even configure the appearance of individual faces.
1 -
alnis
Member, Developers Posts: 453 EDU
Edit: oops, didn't see @romeograham's post, sorry for the double post!
You can add a configuration table in the part studio or configuration variables for red, green, and blue together with the part color custom feature:
Link to document:
https://cad.onshape.com/documents/38914af144736e446f0f9053/v/12d1644364d32f00e6966d6f/e/06b1b5c29436a345e0ea21f1
Get in touch: contact@alnis.dev | My personal site: https://alnis.dev
@alnis is my personal account. @alnis_ptc is my official PTC account.0
Link to document:
