Can I make one piece two different colors?
nate_brown788
Member Posts: 4 PRO
I'm doing a project for my CAD class and I'm making a lot of the same exact part but each one needs to be a different color. I've been making the part individual each time just so I can have it be another color. Is there anyway way to make one piece have multiple colors in an assembly?
Optionsromeograham Member, csevp Posts: 659 PROFor your application, you can configure the color of the part in the Part Studio. You need to create a Configuration table, then in "Configured Part Properties" you set color for each body.
Then, in the Assembly, you can change the configuration of each instance as needed to get the colors you want.
You can even configure the appearance of individual faces.
1 -
Optionsalnis Member, Developers Posts: 449 EDUEdit: oops, didn't see @romeograham's post, sorry for the double post!
You can add a configuration table in the part studio or configuration variables for red, green, and blue together with the part color custom feature:
Link to document:
https://cad.onshape.com/documents/38914af144736e446f0f9053/v/12d1644364d32f00e6966d6f/e/06b1b5c29436a345e0ea21f1
Student at University of Washington | Get in touch: contact@alnis.dev | My personal site: https://alnis.dev0
Link to document:
