In Context Boolean, Mate Connectors Gone
famadorian
Member Posts: 390 ✭✭✭
I edited a part in context, then added a derived part, transformed it and did a boolean union on the parts, but when I return to the Assembly, the mate connectors of the last derived part are gone?;)
Here's the file:
https://cad.onshape.com/documents/2d7dbc7b1261d40143e5ca98/w/fa81af3c990d6fb181f1d4c0/e/51a6f59a7d97cc92bfeee40b
Something I'm doing wrong here?;)
Happens almost all the time
https://cad.onshape.com/documents/727e77bcc01633e6a48e5c08/v/703f703100ef01235b24781a/e/d8f7436596d5fb2a662499e8
Note that if we reverse the order in which the cube and disc are selected, we keep the mate connector when we insert it into the assembly, and the second gray part becomes missing since it was consumed and added to the cube with the mate connector.
This behavior definitely is a bit tricky. I wonder what would be a better way to handle it. One option would be to transfer ownership of mate connectors to the new "parent" part when a part with a mate connector is combined with another part, but I haven't thought much about this and there is probably some sort of drawback that I haven't thought of.
In short, I think this is expected behavior, but it's not super intuitive since the boolean feature merges geometry, but doesn't seem to add other data from the parts that were booleaned together.
