Changing the text size of notes
ron_24ron_24 Member Posts: 14 ✭✭
When I edited an existing note, and typed in a new entry for the text size, I found that while the new size has been permanently added to the list of sizes, it does not cause a change in size to occur to the existing text.
    It will if you highlight the text before changing the size
  • john_mcculloughjohn_mccullough Moderator, Onshape Employees Posts: 38 image
    This is necessary because notes can contain text of different sizes.
    BTW, in the text editor the Ctrl+A shortcut will select (highlight) all of the text, double-click on a word will select it, and triple-click will select all of the text on one line.
    @john_mccullough Thanks for that tip John
