Create Selection from Isolate
famadorianfamadorian Member Posts: 390 ✭✭✭
I've managed to isolate the staircase here, which consists of very many parts. Is there any way to create a selection based on this isolation?
I want to create a composite part.
This is an imported object.
  • alnisalnis Member, Developers Posts: 453 EDU
    Here's what I would do:
    - Activate composite part feature (no need to close isolate if you already have it set up)
    - Activate and set up isolate (if you didn't have it already)
    - Box select all of the stair bits by left clicking and dragging with your mouse
    When parts are transparent because of isolate/make transparent, they aren't selected in box selects.
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    Indeed;). Thanks
