How can I use @opWrap to place a label on a cylinder?
monroe_weber_shirk
monroe_weber_shirk Member Posts: 103 EDU
edited January 2021 in Community Support
I've created a Scale feature that can put a scale (think of one axis of a graph with ticks and numbers) on a plane. I'd like to extend that capability to cylinders so that I can label pipes and round tanks. I've tried to use opWrap and have been unable to figure out what inputs are required. I get the error
@opWrap: Map does not contain field 'anchorPoint'.
I tried adding anchorPoint as a field, but I still get the same error.
The code with opWrap is on line 143
I'd also appreciate any hints on how to debug this type of problem.
