Getting reasonably smooth rendering of Onshape objects in Sketch Up
john_mardirosian229john_mardirosian229 Member Posts: 15
I have exported one of my components in the only format that occurs as both an Onshape Export format and a Sketch Up Import format (STL). The component is a fairly smooth curved shell with a few dozen indents/edges (see first image). In Sketch Up the component appears with a huge number of lines (~ 10,000), making the final view unsightly (see second image). Any ideas on format conversion programs that could bridge the gap, giving me a less accurate but more pleasing result? I have already turned down the Export granularity in Onshape to Coarse, and that is still unacceptable.
  • john_mardirosian229john_mardirosian229 Member Posts: 15
    This issue is resolved. Some research on the web with Google query on making smooth shapes in Sketch Up led to two very useful videos. From Justin Geis, provding a summary of many tools that could solve the issue, those available in Sketch Up baseline and some paid optional tools.
    making rounded shapes in sketch up - Google Search. Second on using the Smoove Tool from Professional CAD Systems at SketchUp - How to use the Smoove Tool - YouTube
    Key find was the comment and demonstration of the Soften/Smooth edges feature available with a right-click on certain objects. The STL exported component is just that kind of object... so the result was great.
  • romeograhamromeograham Member, csevp Posts: 748 PRO
    Thank you for posting your resolution to the issue. That really helps the rest of us that find your question - and then find the answer too!
