Tangent Points on curved entities, Circles, Radii, and Curves
rod_muirhead943rod_muirhead943 Member Posts: 96 EDU
Please look into making the tangent point a larger, bolder, different color icon point when sketching and needing to see the exact tangent location.
Thanks
  • fred_wildfred_wild Member Posts: 29
    I have a similar issue, where I wish to identify the exact point of a tangency to a 2D spline.  Please enable tangent points. Thank you.
  • S1monS1mon Member Posts: 3,748 PRO
    Can you share an example of what you are trying to do - either a public document or screenshot? There’s most likely a way to do what you want between tangent or normal constraints and construction lines.
