Batch-deleting missing external references from a sketch?
edward_panedward_pan Member Posts: 10 ✭✭
It happens often that after I edit something on which some external references for a later sketch exist, the sketch goes red.
I know this doesn't really affect the features next in line and all I have to do is to delete those missing constraints, but sometimes a sketch uses many external references and I have to delete them one by one because those don't seem to be multi-selectable.
I think it would be great to be able to delete those all at once.
  • EvanReeseEvanReese Member, Mentor Posts: 2,865 PRO
    I'd vote for this.
  • wayne_sauderwayne_sauder Member, csevp Posts: 651 PRO
    Does the transform command work to correct the issue? It is not a workflow that I use much but the transform command in the sketch breaks all constraints, maybe that would not have the effect you are looking for.
  • edward_panedward_pan Member Posts: 10 ✭✭
    Yes, it is a useful approach.!
  • Jed_YeiserJed_Yeiser Member Posts: 57 PRO
    @edward_pan
    Have you put an improvement request in for this yet? It would be a MASSIVE help to be able to only remove missing references in sketches the way you can with the SW display/delete references!!
  • Kyler_WalkerKyler_Walker Member Posts: 211 PRO
    @edward_pan
    I created an improvement request for this a while back.
    https://forum.onshape.com/discussion/19283/select-and-delete-multiple-sketch-constraints#latest
