Is it possible to create an aligned section view?
jfordjford Member Posts: 2 EDU
I'm trying to create an aligned section view on an adapter plate that has 5 holes equally spaced and a center keyway.  Since there are 5 holes they are note symmetrical.  I would like to create an aligned section that cuts through one hole, the keyway and another hole.  Is this possible with Onshape?
  • T_RathierT_Rathier Member Posts: 47 EDU
    I would like to see this as well! It seems odd that an aligned section view cannot be made. They are used frequently in mechanical drafting.
