How to shell?
rachel_sheyrachel_shey Member Posts: 2
I made this thing out of a revolve and an extrude which was mirrored.  It won't shell, for some reason.  https://cad.onshape.com/documents/4cac089387125684970106fa/w/9cc9a33465adbabc19749916/e/9c5284baa6bbcc4766235033
It seems like no matter what I try, it won't shell.  What else can I try?  I've tried offsetting the surfaces to see if I can find the error, but it seems like everything will offset.
  • MichaelPascoeMichaelPascoe Member Posts: 2,808 PRO
    edited February 2021
    Sometimes shell doesn't work well with sharp corners. For more in depth help, set your document to public so that we can copy it and find the problem.
    At a glance, looks like these two areas could be causing the problem:
    RENDERCAD
