How to update Feature Studio contents using python client?
oleksandr_slovak
edited February 2021 in FeatureScript
Hi!
I can successfully access feature studio content using python client API by:
element = OnshapeElement("https://cad.onshape.com/documents/ca8f441b906a5949eb4e8196/w/3ffa603f8af8def1150f37d7/e/f85267336902055c5cbf495d")
result = osh.client.feature_studios_api.get_feature_studio_contents(
**element._get_DWMVE(),
_preload_content=True
This gives me valid result with something like:
{'btType': 'BTFeatureStudioContents-2239', 'contents': 'FeatureScript 1447;\n'             'import(path : "onshape/std/geometry.fs", version : "1447.0");\n'             '\n', 'library_version': 0, 'microversion_skew': False, 'reject_microversion_skew': False, 'serialization_version': '1.1.20', 'source_microversion': '422f02088f68947019b7c291'}
But any tries to call update_feature_studio_contents end up with:
Traceback (most recent call last):
  File "/usr/lib/python3/dist-packages/IPython/core/interactiveshell.py", line 3331, in run_code
    exec(code_obj, self.user_global_ns, self.user_ns)
  File "<ipython-input-46-d4661d04e8f2>", line 1, in <module>
    result = osh.client.feature_studios_api.update_feature_studio_contents(
  File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api/feature_studios_api.py", line 613, in __call__
    return self.callable(self, *args, **kwargs)
  File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api/feature_studios_api.py", line 410, in __update_feature_studio_contents
    return self.call_with_http_info(**kwargs)
  File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api/feature_studios_api.py", line 670, in call_with_http_info
    return self.api_client.call_api(
  File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api_client.py", line 367, in call_api
    return self.__call_api(
  File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api_client.py", line 184, in __call_api
    response_data = self.request(
  File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/api_client.py", line 447, in request
    return self.rest_client.POST(
  File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/rest.py", line 400, in POST
    return self.request(
  File "/home/slovak/.local/lib/python3.8/site-packages/onshape_client/oas/rest.py", line 312, in request
    raise ApiException(http_resp=r)
onshape_client.oas.exceptions.ApiException: (400)
Reason: Bad Request
HTTP response headers: HTTPHeaderDict({'Date': 'Mon, 08 Feb 2021 21:28:36 GMT', 'Content-Type': 'application/json;charset=utf-8', 'Content-Length': '91', 'Connection': 'keep-alive', 'On-Version': '1.125.26734.a33400e3c8f4', 'On-Request-Id': '742b3dce8e437fe70dc6de1c', 'Strict-Transport-Security': 'max-age=31536000; includeSubDomains', 'X-Content-Type-Options': 'nosniff', 'X-XSS-Protection': '1; mode=block'})
HTTP response body: {
  "moreInfoUrl" : "",
  "message" : "Error in input",
  "code" : 9999,
  "status" : 400
Is there any working example of how to change the content of the feature studio using API?
So far I've tried:
1. Use API explorer to create working json like: '{"contents": "AAAAAAAAAAAAAAAAA", "serializationVersion": "1.1.20", "sourceMicroversion": "483f72f012aa6e1a6c6853ba", "rejectMicroversionSkew": false}' It works in browser/API explorer.
2. Use it as a body in the call to update_feature_studio_contents -> does not work.
Here is my code:
resp = json.dumps({
"sourceMicroversion": result["source_microversion"],
"rejectMicroversionSkew": False
body=resp
Many thanks for any suggestion!
Best regards,
Oleksandr
