Line thickness
blair_sempleblair_semple Member Posts: 2
Is there a way to customise the line thickness of the views in the Drawings page.  I can see where and how to adjust the lines using the preset thicknesses in the Drawing Properties tab, but I need to set a thickness below 0.10mm to be able to transfer the drawing into a laser cutter.
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    There is a much shorter way to do this.
    Right click on the part in the Partstudio, then you get a menu, select Export dxf, send this to your laser.
  • michael3424michael3424 Member Posts: 757 ✭✭✭✭
    FWIW, I've been using "Export as DXF/DWG" to cut out parts on my home laser for a while now and it has always worked perfectly.
