Drawing a spiral staircase
I'll be honest; I'm stuck... I'm trying to design a 3DP test part whose side plane view is at https://cad.onshape.com/documents/676978fedd5417d8039896d8/w/f2925e7ed8fabc51cb99a883/e/b5dda3a805eb693c40c5c02d
but I can't figure out how to offset each rectangular step (which is obtained by rotating the base rectangle pattern in 5 degree steps) so that they can then be extruded to a depth (e.g., 8 mm) less than the plane spacing (e.g., 10mm). Obviously, they all share the same axis of rotation, but I've stumbled at the offsetting step, so to speak...
- Sketch the bottom or top tread
- Sketch a circle for an axis
- Extrude the circle as a surface to the height you want
- Create a helix around the axis cylinder with it's starting point at the tread
- Curve pattern the first tread along the helix
https://cad.onshape.com/documents/ac8a354a1ed2b1e04bf74db5/w/6020e67766db3d4b5e7bf9fc/e/5c11daa46800db110cc50ac4Also, here is a configured circular stair model I made quite a while back. You are welcome to copy the document and use it. I have learned better techniques for almost everything in this document, but it should work still.
https://cad.onshape.com/documents/93e0f0c7f7b694eb5e967338/w/9a790a123e1e7d340510fe28/e/139193a84d5c60084b0379d4
RENDERCAD
rendercad.ai - Photorealistic product rendering.
RENDERCAD
